what carb can I use for a 96 2 stroke Polaris sportsman 400 4x4
Old 03-25-2017, 02:45 PM
aunder06's Avatar
Default what carb can I use for a 96 2 stroke Polaris sportsman 400 4x4
Was hoping to not have to purchase an OEM carb for this thing since I don't want to invest alot of money. The carb on it had a hole in the housing. Was just wondering if any 34 or 32 mm mikuni round slide carb for work.
Old 03-25-2017, 03:10 PM
VM34 is what is on the 400.Just look for a cheap carb on ebay.
Old 03-25-2017, 07:20 PM
hydrex's Avatar
Have you tried fixing the hole? There are some pretty good materials out there.
Old 03-25-2017, 08:18 PM
aunder06's Avatar
No I haven't. I took it apart to clean it and it looked like some yellow jel in the corner and I scraped it off and discovered there was hole there that someone had previously fixed. But the inside of the housing looked corroded so I thought I may be best off to get a new carb all together. Don't know anything about it so I'm open to any advice you guys can provide and greatly appreciated.
Old 03-25-2017, 08:20 PM
aunder06's Avatar
Im finding different vm34s on eBay and Amazon that are pretty affordable but some have lever chokes which doesn't matter to me but my question is which one should I use and do I need to rejet
Old 03-26-2017, 09:26 AM
Levers can be removed and your cable choke can be used. Always check jetting against the oem carb. If you have to use you main and pilot jet.A lot easier if you just post in one section and not in multiple locations. Just confuses people.
Old 03-26-2017, 10:10 AM
aunder06's Avatar
Thanks for the advice. Sorry about that
