Carb Help Please
#16
Found out a month or so ago that the carb on a Raptor 80 is notorious for those screws backing out. My buddy's kid had one and all of a sudden it lost compression. Turns out one of the screws had lodged against on of the valves holding it open. The other bounced around in the cylinder for a while. Needless to say they needed a whole new top-end that was only partially paid for by Yamaha.
I'm not sure if lock-tite is impervious to gas or not but you need to do something to keep them from backing out!
Did you get them out or are they still in there?
#18
Can you apply Loctite and get the screws back in,the "red" permanent loctite should hold.
When you clean a carb you just clean the choke plunger,pilot jet,main jet and pilot air jet.
here a good how to link on cleaning a carb.Disassembly and Cleaning of a Mikuni Round slide Carburetor
Its a slide carb not a CV but all carbs have the same parts to clean.
#19
