older 250 quadrunner question
Old 01-21-2014, 09:57 PM
yosam's Avatar
Default older 250 quadrunner question
hey guys , i have 86-89 250 quadrunner , it runs but hard to start , and i know rings are bad , would the rings cause the starting problem , i mean when cold takes forever to get going , when heated up , starts right up , leave for awhile and then all same again , thanks in advance
Old 01-21-2014, 11:09 PM
papa hogg scoot's Avatar
May do an compression reading should be 120 to 160 pounds..Im guess tight intake value adj.both vales this could help cold start ups.. if an value is to tight the rocker will hold value open an lil bit an loose compression but once cranked up then cyclinder is already primes so this is why restarts are alot easier until leaks back down an hard starts again..Good Luck
Old 02-07-2014, 11:30 AM
hw1353's Avatar
I'll bet you anything that you need to adjust the intake valve. I bought my quadrunner for 50 bucks, motor was stuck. I wanted to see if it would run, all I had to do was adjust the intake valve. .03-.05 with a feeler gauge is normally what I do. Will start first bump on the starter.
cornermike
09-10-2015 08:30 AM
Bigtwin700
09-09-2015 09:32 AM
Rooky
09-09-2015 03:16 AM
Kenidah
09-07-2015 07:50 PM
09-01-2015 11:59 PM
Quick Reply: older 250 quadrunner question
