What is the hole in the fuel cap 230s Quadsport for?
Old 12-11-2016, 05:37 PM
BlackDogBrewing's Avatar
Default What is the hole in the fuel cap 230s Quadsport for?
I picked up a LT23S today for cheap. The fuel cap has a tiny hole in the top of it. Is there supposed to be a tube on there? If so, where does it go? Thanks.
Old 12-11-2016, 05:50 PM
Tank atmospheric vent. Tank has to have air or the fuel system can vapor lock. Run a hose up under the front panel or down the steering post as long as the post is open and tube doesn't kink. Here's a free pdf service manual. Let it load up,takes a little bit. This can help you on many service and repair problems. https://docs.google.com/leaf?id=0Bz8...ut=list&num=50
Old 12-11-2016, 08:12 PM
Thank you!
