Quadzilla 500es
Not that hard. Most clutches whether on atvs or street bikes use the same style friction and steel plates. You can make a card board template to hold the screws so the can be replaced in the correct position. Drain oil or lean the machine over. Here's a couple vids that can help.
You'll usually have to adjust clutch free play at the lever when through.
