Need help with yamaha warrior jetting.......
Old 01-19-2008, 06:30 PM
alljuice's Avatar
Default Need help with yamaha warrior jetting.......
I have a 98 warrior with a k and n filter and full cobra exhaust... Dyno jet says to use a 136.... What is the mikuni equivilent jet? Thanks
Old 01-19-2008, 07:03 PM
87 warrior's Avatar
i have a k&n filter as well but a white brothers e-series exausht and i run a 150 main jet. the 136 is well under stock useually you would go bigger on the main jet after putting a pipe on plus having the k&n filter.
jetting can also be a pain in the *** sometimes it's something you have to play around with.
Old 01-21-2008, 12:12 AM
recon99's Avatar
I didn't memorize the dynojet to mikuni chart, but your best jetting will most likely be a 150, depending on your conditions (altitude, temperature, etc) you may need to go to a 147.5 or a 152.
2quiker
03-22-2022 08:36 PM
09-17-2015 03:06 AM
Yamaha Side by Sides
09-08-2015 01:43 PM
Quick Reply: Need help with yamaha warrior jetting.......
