2004 raptor 660
Old 04-15-2013, 10:27 PM
Wager1988's Avatar
Default 2004 raptor 660
It won't move you put it in gear and it just sits there. Before this it was popping like the chain was loose so I tightened it and it stopped now it just won't move. Can anyone help with this?
Old 04-17-2013, 09:49 AM
Airb's Avatar
Do the RPM's fluctuate with the release of the clutch lever? Does the machine stall following the release of the clutch lever? Are there any noises coming from the case or driveline? Are the splines on the shifter worn out? Is the shifter assembly tight? I would start with the clutch, maybe you broke a plate.
Old 04-17-2013, 11:19 AM
Raptor450's Avatar
Clutch plates probably need replaceing.
2many2ride
09-27-2015 04:35 AM
exmotocrosser
09-26-2015 08:18 AM
Bernhard
09-25-2015 12:45 PM
Sw00p
09-24-2015 02:50 PM
black_thunder
09-22-2015 07:59 PM
Quick Reply: 2004 raptor 660
