2001 raptor 660 carb
Old 08-06-2013, 06:46 PM
brandon2013's Avatar
Default 2001 raptor 660 carb
I was going to buy a used carb that has been jetted for a certain exhaust. Since the carbs were jetted can I use them on a quad with a stock exhaust. I was planning on no airbox lid with stock exhaust until I get enough money to buy a full exhaust system.
Old 08-07-2013, 01:02 PM
littlenev's Avatar
It will spit and sputter probably because its not jetted for a stock pipe. Use the stock jetting until you get the exhaust and then switch carbs.
Old 08-07-2013, 03:36 PM
Raptor450's Avatar
You might be fine if you run no airlid and possibly an aftermarket filter. Why couldn't you just buy new factory jets and install them while the carbs are off? They're real easy to swap out once the carbs are off, and cheap - like $2 apiece and I think there's 4 total on the 660 = $8.
Dirtbikemike1
Technical and How-To Articles
10
07-12-2015 07:22 PM
Dirtbikemike1
07-11-2015 03:36 PM
black_thunder
07-09-2015 05:58 PM
Dirtbikemike1
07-09-2015 01:27 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
07-08-2015 02:16 PM
Quick Reply: 2001 raptor 660 carb
