2005 Suzuki LT 160
2005 Suzuki LT 160
The LT 160 combines a reliable 158cc 4-stroke power plant with a single cylinder, electric start with maintenance free CDI ignition system. A automatic clutch provides quick acceleration in any situation and also features an easy to use reverse gear.
The single A-arm oil damped front suspension and single shock rear suspension with preload adjustment provides comfort and agility over any kind of terrain. New generation yellow bodywork combined with a 2.24 gallon fuel tank, standard rear brake light and large 45 watt headlight complete the Quadrunner LT-160 package.
Features
- N/a
Specifications
- Engine: 4-stroke, single-cylinder,
- Piston Displacement: 158cc (9.6 cu. in.)
- Bore x stroke: 58.0 mm (2.283 in.) x 60.0 mm (2.362 in.)
- Compression ratio: 9.2:1
- Carburetion: Mikuni VM20
- Ignition: Electric & recoil
- Transmission: 5-forward, w/reverse
- Final drive: (Chain) RK520SM, 84 links
- Frame:
- Suspension front / wheel travel: Independent, single Aarm, oil damped
- Suspension rear / wheel travel: Swingarm, oil damped Caster: 8º
- Front tire: AT20 x 7-8
- Rear tire: AT22 x 10-8
- Front brakes / rear brake: Drum / Drum
- Overall length: 1610 mm (63.4 in.)
- Overall width: 985 mm (38.8 in.)
- Wheelbase: 1070 mm (42.1 in.)
- Ground clearance: 135 mm (5.3 in.)
- Seat height: 725 mm (28.5 in.)
- Lighting:
- Rack capacity, front / rear:
- Towing capacity:
- Fuel capacity: 8.5 L (2.2 gal.)
- Dry weight: 155 kg (341 lbs.)
- Instruments:
- Color choices:
- MSRP:
