2005 Suzuki LTZ 400
Powering the 2004 Quadsport Z400 is a high performance398cc aluminum-alloy 90.0mm X 62.2mm, four-stroke, liquid cooled, DOHC single cylinder powerplant with four valves actuated by cam lobes riding directly on bucket tappets. The cylinder head features a narrow 28 degree included valve angle for a compact, efficient combustion chamber with a 11:3:1 compression ratio.
Fuel is supplied by a 36mm Mikuni carburetor feeding 36mm intake valves, with exhaust leaving through 29mm exhaust valves. A dry sump lubrication system helps to create a more compact engine package. The aluminum-alloy cylinder is plated with Suzuki’s own race proven nickel phosphorus-sillicon-carbide coating, to reduce weight and improve heat transfer, allowing for tighter more efficient piston-to-cylinder clearance.
A manual 5-speed transmission, with reverse gear transmits horsepower to the wheels, while a handy knob on the left front fender releases the reverse interlock to select the reverse gear with final drive transmitted through an O-ring sealed roller chain.
The chassis features a lightweight, rigid, high-tensile steel alloy tube frame and sub-frame, along with an independent double-wishbone front suspension with preload adjustable coil over shocks. Out back an aluminum alloy swingarm rear suspension utilizes a single fully adjustable piggyback reservoir shock.
- N/A
- Engine: 4-stroke, single-cylinder, liquid-cooled, DOHC
- Piston Displacement: 398cc (24.3 cu. in.)
- Bore x stroke: 90.0 mm (3.543 in.) x 62.6 mm (2.465 in.)
- Compression ratio: 11.3:1
- Carburetion: Mikuni BSR36
- Ignition: Electric
- Transmission: 5-speed w/reverse
- Final drive: chain (520, 96 links)
- Frame:
- Suspension front / wheel travel: Independent, double Aarm, oil damped / 215 mm (8.5 in.)
- Suspension rear / wheel travel: Swingarm-type, oil damped / 230 mm (9.1 in.)
- Front tire: AT22 x 7 R10 ..
- Rear tire: AT25 x 10 R9 ..
- Front brakes / rear brake: Disc / Disc
- Overall length: 1830 mm (72.0 in.)
- Overall width: 1165 mm (45.9 in.)
- Wheelbase: 1245 mm (49.0 in.)
- Ground clearance: 935 mm (36.8 in.)
- Seat height: 810 mm (31.9 in.)
- Lighting:
- Rack capacity, front / rear:
- Towing capacity:
- Fuel capacity: 10.0 L (2.6 gal.)
- Dry weight: 169 kg (373 lbs.)
- Instruments:
- Color choices:
- MSRP:
