2005 Suzuki Ozark 250
Named after Mt. Ozark in Arkansas, the LTF-250 is built to be practical, accessible, convenient and a completely enjoyable experience for everyone. The Ozark features a single-cylinder, overhead cam design with a bore and stroke of 66mm X 72mm creating a full 246cc’s of torque producing motor. A centrifugal-automatic clutch works with a smooth shifting wide ratio 5-speed transmission, a convenient reverse gear and low-maintenance 2X4 shaft drive system.
Air cooling and a wet sump oil system help make the Ozark simpler and lighter, while an electronic CDI ignition system and automatic cam chain tensioner allow for reduced maintenance. The SOHC valve train uses rocker arms and simple screw tappets for easy valve adjustments, while the auxiliary starting system is a recoil pull type. A single 29mm carburetor, large capacity airbox, and tuned exhaust system combine to produce a broad powerband with emphasis on mid-range torque.
Anchoring the Ozark is a rugged steel tube chassis featuring a 44.9 wheelbase, 8.5 feet turning radius and 8.3 inches of ground clearance. Suspension duties are handled by an independent double wishbone, coil over dual shock arrangement in front with 5.5 inches of wheel travel, and a single shock swingarm rear suspension also providing 5.5 inches of wheel travel in the rear. The LTF250 is packaged with a stylish modern look and it is equally happy at work or play, and comes with a value price tag.
- N/A
- Engine: 4-stroke, single-cylinder, air-cooled, SOHC
- Piston Displacement: 246cc (15.0 cu. in.)
- Bore x stroke: 66.0 mm (2.598 in.) x 72.0 mm (2.835 in.)
- Compression ratio: 9.2:1
- Carburetion: Mikuni BS29SS
- Ignition: Electric & recoil
- Transmission: 5-forward, w/reverse
- Final drive:
- Frame:
- Suspension front / wheel travel: Independent, single Aarm, oil damped
- Suspension rear / wheel travel: Swingarm, oil damped
- Front tire: AT22 x 7-11 P
- Rear tire: AT22 x 10-9 P
- Front brakes / rear brake:
- Overall length: 1800 mm (70.9 in.)
- Overall width: 1045 mm (41.1 in.)
- Wheelbase: 1140 mm (44.9 in.)
- Ground clearance: 210 mm (8.3 in.)
- Seat height: 785 mm (30.9 in.)
- Lighting:
- Rack capacity, front / rear: 44 lbs.
- Towing capacity:
- Fuel capacity:10.6 L (2.8 gal.)
- Dry weight: 183 kg (403 lbs.)
- Instruments:
- Color choices:
- MSRP:
