2007 Brute Force 650 4×4 ATV
Powerful, rugged and a great performer in an affordable package
While the competition sells some nice big-bore all-terrain vehicles (ATVs) with single-cylinder engines and four-wheel drive, the Brute Force™ 650 4×4 comes with Kawasaki’s legendary V-twin engine, a leading-edge 4×4 system and angular good looks for about the same price.
The Brute Force 650 4×4 is powered by Kawasaki’s highly acclaimed liquidcooled 633cc, 90-degree V-twin engine featuring single overhead cams and four valves
per cylinder. It is fed by dual 32mm Keihin carburetors drawing fresh air from a snorkel intake located high in the frame near the steering head. Together, these powerplant features provide the rider with industry-leading torque and smooth-running operation unmatched by the competition.
Power is then transferred to Kawasaki’s much-acclaimed fully automatic continuously
variable transmission (CVT). With high or low forward gears, plus neutral and reverse, this proven transmission functions seamlessly, providing excellent control for both low- and high-speed work or recreational riding. Plus, the Brute Force 650 4×4 can also be started in any gear, provided the brakes are applied.
Complementing the CVT is a switch on the right handle bar that gives the rider a choice of either two-wheel or four-wheel drive operation, and power is delivered to the wheels by dependable, low-maintenance shaft drive. In normal four-wheel drive mode, the front wheels provide extra traction for adverse terrain, while the limited-slip differential allows the rider to make tight turns and reduces steering effort.
As expected, the Brute Force 650 4×4 includes Kawasaki’s Variable Front Differential Control, a favorite feature often praised by editors of the leading ATV magazines. By pulling a small lever on the left handlebar, the rider can deliver equal amounts of power to both front wheels, a definite advantage for riders encountering deep mud and slippery uphill trails or when traversing over large objects such as logs or rocks.
The Brute Force 650 4×4 braking system also benefits from leading-edge Kawasaki design. Dual front disc brakes with dual-piston calipers are matched to Kawasaki’s sealed, oil-bathed, multi-disc rear brake system. As an integrated part of the shaft drive, the rear braking system is sealed in the aluminum swingarm where it operates in an oil bath. This protects the brake pads from mud, dust and debris, and is virtually
maintenance-free.
Working in conjunction with the high-performance brakes is the Kawasaki Engine Brake Control system, which electronically monitors ground speed and uses the engine’s compression to help slow the ATV.
Kawasaki’s 4×4 ATVs have a well-deserved reputation for providing smooth, comfortable rides and the Brute Force 650 4×4 carries on this tradition. MacPherson strut front suspension with 6.7 inches of travel grace the front end, while the aluminum swingarm rear suspension features a fully adjustable spring, piggy-back reservoir and 7.2 inches of travel.
Additional comfort is provided by a large saddle and adjustable footpegs mounted atop full-size floorboards. To help reduce unsprung weight and further enhance the smooth ride, the Brute Force rides on aluminum wheels.
The Brute Force 650 4×4 is wrapped in tough-looking bodywork styled after its bigger sibling, the Brute Force™ 750 4x4i. With its modern, aggressively angled lines complemented by cat-eye headlights, the bodywork is made from Thermo-Plastic Olefin, which has an ultra-high gloss appearance and is scratch-resistant.
Other features include front and rear steel racks that can carry a total of 264 pounds of cargo, and a tow hitch so it can tow up to 1,250 pounds. Kawasaki engineers also provided space inside the front guard so it can accommodate a Warn 3000 winch or Super Winch 3000.
The Brute Force 650 4×4 comes with fully digital instrumentation, including speedometer,
odometer, dual resettable trip meters, clock, hour meter, fuel gauge and 2×4/4×4 indicators. There is also a DC power outlet.
Authentic Kawasaki Accessories are available through Kawasaki dealers or they can be purchased on the Internet at www.kawasaki.com.
As with all off-highway vehicle recreation, Kawasaki encourages ATV riders to ride responsibly and to respect the environment. Kawasaki will pay first-time buyers of a new Kawasaki ATV 0 for completing an ATV rider safety course conducted by the ATV Safety Institute (ASI). Interested consumers can call ASI toll-free at 800-887-2887.
Kawasaki Motors Corp., U.S.A. (KMC) markets and distributes Kawasaki motorcycles, ATVs, personal watercraft and utility vehicles through a network of more than 1,500 independent retailers, with an additional 7,700 retailers specializing in power products and general purpose engines. KMC and its affiliates employ nearly 2,400 people in the United States, with 400 of them located at the Irvine, California headquarters.
™ Kawasaki’s tagline, “Let the good times roll. ”, is recognized worldwide and the brand has become synonymous with powerful, stylish motorcycles for over four decades. Information about Kawasaki’s complete line of recreational products and Kawasaki affiliates can be found on the Internet at www.kawasaki.com.
Combines the best of Kawasaki’s award-winning 4×4 ATVs
- The smooth torque of Kawasaki’s original V-twin engine
- An advanced chassis, suspension, automatic transmission and brakes
- Tough body style
- Engine:
- Displacement:
- Bore x stroke:
- Compression ratio:
- Carburetion:
- Ignition:
- Transmission:
- Final drive:
- Frame:
- Suspension front / wheel travel:
- Suspension rear / wheel travel:
- Front tire:
- Rear tire:
- Front brakes / rear brake:
- Overall length:
- Overall width:
- Wheelbase:
- Ground clearance:
- Seat height:
- Lighting:
- Rack capacity, front / rear:
- Towing capacity:
- Fuel capacity:
- Dry weight:
- Instruments:
- Color choices:
- MSRP:
