2008 Honda TRX700XX
Honda has once again upped the ante for those who want a big, lean and powerful machine with the all-new 2008 TRX 700XX– featuring the most powerful ATV engine Honda has ever built. Radical body styling makes this the most extraordinary Sport ATV that Honda has produced. Thanks HRC!
With a 686cc SOHC liquid-cooled motor, this is the machine to conquer the dunes and terrain. The five-speed manual transmission is standard; also new for the 700XX is a reverse gear that is fairly easy to engage.
The 700XX is the only sport quad in its class to have a double wishbone suspension. Independent double-wishbone front suspension uses premium shock absorbers featuring dual single-rate springs that allow a lighter, more compact package with 10.5 inches of fully useable travel. For the rear it is almost the same setup. Independent double-wishbone rear suspension, made possible by the innovative centered chain drive system – features steel upper and aluminum lower A-arms. Using piggy-back reservoir shocks, the system provides 9.3 inches of fully useable travel.
With all the power and torque in this ATV one may wonder: how’s the brake handle? Two large dual hydraulic discs in the front and one in the rear make this ATV great for braking and sliding around burms and ruts, and maneuvering away from rocks with ease. The Radial tires with knobby pattern provide superb traction and cornering ability. Adding even more traction are the special, large-diameter 11-inch aluminum rear wheels, which allow for ideal CV joint angles and A-arm lengths. This results in superior power delivery, optimum suspension action and improved durability.
Riding, racing, good looks, and comfort will be on everyone’s mind. The tough, polyethelene push bar up front and polypropelene rear A-arm protectors are sharp
and stylistic. A sculpted, plush seat provides excellent comfort and superb sport riding ergonomics. Finally, an ATV for those long days, pushing the limits from dawn till dusk. The cowl-integrated headlight with dual 30-watt bulbs and a rear LED Brakelight provides distinctive sport style and excellent functionality.
With all this power and technology the 700XX is a massive 508 pounds (with all standard equipment, full tank of fuel at 3 gallons and all other needed fluids).
Although Honda is adding new color options, one traditional is still intact: Red – Metallic Black/Silver or Metallic Black/Red.
Features
- All-new 686cc SOHC liquid-cooled fuel-injected four-valve single-cylinder four-stroke engine, the most power in its class.
- Double-wishbone Independent Rear Suspension (IRS) with tuned sway-bar.
- Centered chain final drive system.
- In-gear starting in Forward or easy-to-use Reverse.
- Piggy-back rear shocks with adjustable pre-load. Dual-spring front shocks with adjustable pre-load.
- 11-inch diameter rear rims with removable mud scrapers. Radical new-style bodywork.
- Available colors are Metallic Black / Silver and Metallic Black / Red.
- Liquid cooling provides consistent engine operating temperature in extreme conditions for maximum power and long engine life.
- Heavy-duty clutch stands up to sport-ATV demands.
- Transferable one-year, limited warranty; extended coverage available with a Honda Protection Plan.
- Purchase of a new, previously unregistered Honda USA-certified unit by an individual retail user in the United States qualifies the owner for a one-year complimentary membership in the Honda Rider’s Club of America® (HRCA®).
Specifications
- Model: TRX700XX Engine Type: 686cc liquid-cooled SOHC dry-sump single-cylinder four-stroke
- Bore and Stroke: 102mm x 84mm I
- nduction: Keihin PGM-FI with a 44mm throttle-body fuel injection system
- Ignition: CD with electronic advance
- Starter: Electric
- Clutch: Manual
- Transmission: Five-speed with Reverse
- Driveline: O-ring-sealed #520 chain Front
- Front Suspension: Independent double-wishbone with dual single-rate springs provide 10.5 inches of travel.
- Rear Suspension: Independent double-wishbone with piggy-back reservoir shocks provide 9.3 inches of travel
- Front Brakes: Dual hydraulic 174 mm discs
- Rear Brakes: Single hydraulic 200mm disc
- Front Tires: 21x 7R 10
- Rear Tires: 22x 9R 11
- Length: 73.6 inches
- Width: 45.4 inches
- Height: 45.4
- Wheelbase: 49.8 inches
- Seat Height: 33.3 inches
- Curb Weight: 508 Lbs (Includes all standard equipment, required fluids and a full tank of fuel—ready to ride)
- MSRP ,899.00
