2009 Can-Am Renegade 500
2009 Can Am Renegade 500
Occasionally a model comes along that blurs the lines of classification in the ATV industry. Can-Am’s Renegade 500 is one such model. With a sporty fuel injected 499.6cc high output V-twin engine mated to a 4 x 4 drive train, the Renegade combines the concept of performance trail riding with the durability of a utility machine. Like its bigger brother (introduced in 2008), the Renegade 800R, the 500 aims to appeal to a wider audience with a 00 lower MSRP.
Features
  • Rotax V-Twin 499,6cc EFI engine
  • RS-type TTI rear suspension
  • Visco-Lok 4×4 Front Differential
  • RS-type double A-arm front suspension
  • Multi-function digital gauge
Specifications
  • Engine: V-twin, liquid-cooled, SOHC, 8-valve (4-valves per cylinder)
  • Displacement: 499.6cc
  • Bore x stroke: 82 x 47 mm
  • Carburetion: 46mm Throttle Body, 2 Siemens VDO injectors
  • Transmission: CVT, sub-transmission with high, low, park, neutral & reverse, Standard Engine braking
  • Frame: SST
  • Suspension front / wheel travel: 8.5 inches
  • Suspension rear / wheel travel: 9.0 inches
  • Front tire: ITP Holeshot ATR – 25 x 8 x 12 in ITP Holeshot ATR – 635 x 203 x 305 mm
  • Rear tire: ITP Holeshot ATR – 25 x 10 x 12 in ITP Holeshot ATR – 635 x 254 x 305 mm
  • Front brakes / rear brake: 2 hydraulic discs / 1 inboard hydraulic disc
  • Overall length: 86 inches
  • Overall width: 46 inches
  • Wheelbase: 51 inches
  • Ground clearance: 11 inches
  • Seat height: 34.5 inches
  • Lighting: 4 fender mounted Projector Beam headlamps (60W)
  • Rack capacity, front / rear:
  • Towing capacity: 35 pounds
  • Fuel capacity: 5.3 US Gallons
  • Dry weight: 607 pounds
  • Instruments: Speedometer, tachometer, odometer, trip and hourmeters, fuel, gear position, 4×4 indicator, diagnostics, auto shut off.
  • Color choices: Red or Yellow
  • MSRP: 99
