2009 Suzuki LT-Z90 Review
Suzuki wisely offers ATV configurations in the hopes of grabbing hold of potential riders early and growing with them as the brand of choice. Bridging the gap between the 50 and 250cc variations is the versatile and stylish LT-Z90.
The QuadSport Z90 is designed for adult-supervised riders age 12 and older, and includes many safety features, such as simple screw-type throttle limiter which allows parents to control maximum speed that make learning to ride a safe and fun experience. Value, aggressive R450-like styling, ease of use and reliability, these are traits of the QuadSport Z90.
Features
Key Features
- QuadSport Z90 is designed for adult-supervised riders age 12 and older – includes many features that make learning to ride a safe and fun experience
Engine Features
- Electric starting system plus standard backup recoil starter
- Compact 90cc 4-stroke, single-cylinder, air-cooled engine designed for durability and low maintenance
- Suzuki Composite Electrochemical Material (SCEM) cylinder, derived from Suzuki’s high-performance, high-mileage GSX-R sportbikes, provides durability, weight reduction and superior heat transfer
- Clean-burning four-stroke engine meets the strict emissions regulations imposed by the California Air Resources Board (CARB)
- Smooth-running CVT automatic transmission provides easy operation and allows the rider to focus on riding instead of shifting
- Simple screw-type throttle limiter allows adult supervisors to limit the maximum power deliver to suit a rider’s ability.
- Large 1.6-gallon fuel tank for long operating range combined with vacuum fuel petcock for low maintenance
Chassis Features
- Modern styling with full floorboards and a big Quad look, plus bright yellow or white paint and graphics
- Child-size (Y-12) controls for easy operation
- Strong, high-rigidity steel frame is sturdy and compact. This machine has a low seat height of just 25.6 inches.
- Single A-arm front suspension with twin independent shock absorbers, and single-shock rear suspension provide long wheel travel for a comfortable ride
- Large diameter semi-sealed front drum brakes and single fully sealed rear drum brake provide strong braking performance
- One-piece 8-inch wheels with tubeless tires provide a smooth comfortable ride
- Drive shaft has double oil seals for long-life performance.
- Suzuki T-shaped seat similar to the LT-R450 for smooth weight transition and a comfortable ride, and is easy to remove for simple maintenance
- Headlamp style front piece is detachable to achieve the race machine look of the LT-R450
Special
- Minimum Age: 12 Years Old
Specifications
- Specifications QuadSport Z90
- Model Number LTZ90K9
- Type Sport
- Warranty 12 month limited warranty.
- Suggested Retail 99
- SEP 4
- Engine 4-stroke, air-cooled
- Bore & Stroke 45.5 mm (1.791 in) x 55.2 mm (2.173 in)
- Compression Ratio 9.5 : 1
- Fuel System MIKUNI VM16, single
- Lubrication Wet sump
- Ignition Electronic ignition (CDI)
- Starter Electric and recoil
- Transmission Automatic
- Final Drive RK530, 60 links
- Overall Length 1505 mm (59.3 in)
- Overall Width 875 mm (34.4 in)
- Overall Height 915 mm (36.0 in)
- Seat Height 650 mm (25.6 in)
- Ground Clearance 150 mm (5.9 in)
- Wheelbase 1005 mm (39.6 in)
- Dry Weight 127 kg (280 lbs)
- Suspension Front Independent, swing axle, coil spring, oil damped
- Suspension Rear Swingarm type, coil spring, oil damped
- Brakes Front Drum brake
- Brakes Rear Drum brake
- Tires Front 0
- Tires Rear 0
- Fuel Tank Capacity 6.0 L (1.6/1.3 US/Imp gal)
- Color Yellow, White
* Specifications and features are subject to change
