Amped for Ramps: RUSH Double Jointed Ramps Are All About Storage
When it comes to ATVs, transportation is a fact of life. And when it comes to transportation, the smaller the form factor the better. We’ve all loaded up the bed of pickup trucks or the back of vans with the quad, fuel, gear bag, water bottle, tools, boots and realized that there no room left for the ramps themselves.
Cumberland, Wisconsin’s YTRAX thinks they have this age-old conundrum solved once and for all. Thanks to patented Double-Jointed Technology, RUSH Packable Ramps will fit where ordinary ramps won’t. First, fold them in half; then pivot them flat to store them where other ramps won’t fit. RUSH ramps are designed for maximum pack-ability. Store them behind the seat of your truck, slide them under your ATV, carry them with you on your ATV, or store them in your pick-up toolbox. RUSH ramps fit in places you never thought possible.
Ideal for loading both ATVs and UTVs, RUSH Ramps are rated to support 2,000 lb – a full ton- making them strong enough to load even a heavy UTV. Made of aircraft-grade aluminum construction, RUSH ramps are lighter than steel and will not corrode.
The Stay-Straight Design features raised side rails that form a “V” to keep wheels centered on the ramp. The Tight-Gap Rung Placement also means more rungs per foot, so even small-wheeled machines like lawn mowers can smoothly be loaded with RUSH ramps. Once unfolded, the clever Self-Locking Deployment of the “double-jointed” RUSH ramps automatically locks the ramp into its open position. The technology is foolproof, and there are no added parts to fail.
Ordinary folding ramps present a storage problem when not in use. They may not fit in your trailer; they likely won’t fit in the bed of your truck; and they almost certainly won’t fit inside your truck where they are safe from theft.
