Ask The Editors: Are There Left Hand ATV Throttle Kits?
Custom
Dear ATVC: Looking for a good solid throttle that can be mounted on the left side – anything but the Goldfinger (tried it, didn’t like it). This is needed not because of choice but because of not being able to use right hand completely. Thought I saw one on eBay but any help would be appreciated. Thanks in advance. ATV Momma
Well if the Full Throttle Inc.’s Goldfinger wasn’t to your liking, that pretty much leaves you limited to custom built left-side throttle kits.
Fortunately there are some fabricators out there (like this one on eBay) who offer units for around $65-$75 designed to work with most Honda and Yamaha ATVs without any modification required.
We’re not sure what about the Goldfinger didn’t appeal to you but we do agree the transition from a typical throttle configuration to an inverse lever could be difficult. If all other avenues fail, it may be worth your time to bring your Goldfinger equipped quad to some area shops and inquire about potentially adapting the system to a traditional throttle set-up. Additionally, installing a twist throttle conversion kit is an option to ditch the Goldfinger’s lever set-up.
