Ask the Editors: Honda ATV Key Code
Honda ATV Key Code Identification Help
Let’s do some decoding.
Dear ATVC: I have a 2024 Honda TRX520FE and I have lost my keys. Yes both of them. Question – I pulled the ignition and there are two codes on the plastic housing on the outside of the ignition switch. “2XED50” and “R45”
I know the format D50 would fit as a key code. Any input from someone who is in the know would be greatly appreciated. Is this the key code?
ALL Honda ATVs from 1983-present use the same basic key code for the dealership to identify – One letter followed by two numbers. Letter will always be A-D.
A, B, C, or D followed by a 2 digit number.
You have the code nearly completely solved. The 2x means it came from the factory with two keys. E for electric start and the actual key code would be D50.
Ask the Editors
