Ask The Editors: Where Is My Air Box?
An aftermarket ATV intake.
Dear ATVC: I bought a 1993 Suzuki LT230 Quad Sport and the dude said he did some “mods” because he raced a little. He took off the air box and left only a small air filter. It’s not protected from water or dirt and connects straight to the carb. I’ve cleaned the carb and it still bogs out a little. Is this most likely the air filter or is it something else? And should I purchase an air box for it to keep it protected from dirt and make it like stock again? Thanks
What you’re describing is known as an aftermarket air intake. The principle here is an easy one – allowing the maximum amount of air into the engine should increase its performance over the restrictive nature of a choked up air box.
We say “should” because if the machine is bogging as you describe, it sounds to us like the former owner removed the air box but didn’t properly rejet the carb to accommodate for the increase in air flow. In which case, you’re right, returning it to the stock configuration would likely cure the hiccup.
As for whether or not that is the right thing to do – you get our vote if you’re planning on using the machine as intended – which is to say trails, mud, snow etc. The performance gains associated with ditching the air box for an after market intake are usually the domain of racers who use their machine only in ideal conditions on a properly-groomed track.
Also, the LT230 was around for many, many years. You should have no trouble finding a used box on the likes of eBay.
Ask the Editors
