Bent A-Arms? Zbroz Has Your Back.. Er Front
The Broz want to get you back on the trails.
We are generally big fans of the aftermarket – what’s not to like about getting components often souped up but much cheaper than OEM?
To that end, Zbroz reminds us that stock A-arms on most UTVs are easily damaged by hard impacts from careless or aggressive driving. Zbroz Pro Max Lower A-Arm Kits are far stronger than stock because they are built from 1.5″ OD Chromoly DOM Tubing with a swaged end and pre-installed greasable brass bushings.
They are lighter, much stronger and offer more clearance than OEM A-Arms.
Made in USA, these direct replacement parts are easy to install, with no modifications necessary and use OEM ball joints. A durable powder coated finish assures lasting good looks.
They’re available for Polaris RZR XP 1000, RZR Turbo S, Can-Am X3 rs and X3 ds (but do not fit Can-Am Smart Shock models).
MSRP is $650-$1199. Get them from https://www.zbrozracing.com
