Here Come the 2017 Arctic Cats
Wildcat
WILDCAT SPORT XT EPS & WILDCAT SPORT LIMITED EPS
The 60” wide Wildcat Sport XT EPS and Wildcat Sport Limited EPS return for 2017, but there’s no base model as in 2016. These machines are powered by 700cc double overhead cam, 8 valve inline twins with 60+ horsepower. The Team Rapid Response CVT assures quick power delivery. Double A-arm front suspension gives 12.2 inches of travel. Double A-arm rear suspension with a sway bar offers 12.6 inches.
Wildcat Sport Limited EPS’s come with 2.5” Elka Stage Stage 5 piggyback reservoir shocks featuring adjustable high speed compression, low speed compression, rebound and spring preload. The Limited also includes full doors, aluminum wheels, power steering and Dynamic Gray painted bodywork.
On the Wildcat Sport XT you get 2.5” JRi piggyback reservoir shocks with adjustable compression damping and spring preload. The Sport XT comes with half doors, aluminum wheels, power steering and black painted bodywork. The Wildcat Sport XT EPS is $14,599 and Wildcat Sport Limited EPS is $15,999.
WILDCAT TRAIL, WILDCAT TRAIL XT EPS & WILDCAT TRAIL LIMITED EPS
Arctic Cat’s Family of 50” Trail UTVs are powered by the same 700cc double overhead cam, 8 valve, 60+ horsepower inline twins as the 60” Sports with Team Rapid Response CVTs. These machines have 10” of front suspension travel and 10.5” in the rear using spring preload adjustable Fox nitrogen charged shocks. Front and rear swaybars ensure flat, stable cornering.
WildcatTrail_Trail
The top of the line Trail Limited comes with full doors, aluminum wheels, power steering and White Metallic painted bodywork.
Wildcat Trail XTs have half doors, aluminum wheels, power steering and Vibrant Red Metallic or True Timber Camo painted bodywork.
The base Wildcat Trail comes with half doors, steel wheels, unpainted bodywork and without power steering. The Wildcat Trail is $11,999, the Wildcat Trail XT EPS is $12,999 and the Wildcat Trail Limited is $14,499.
PROWLER
Prowler
Prowler recreation utility UTVs are available with a 951cc single overhead cam 8 valve V-twin, a 695cc single overhead cam 4 valve single or a 443cc single overhead cam 4 valve single. The 1000 and 700 have double A-arm front and rear suspension with 10 inches of travel. Their tilting beds can carry 600 pounds, and there’s a huge storage compartment under the hood. The Prowler 1000 XT EPS and 700 XT EPS come with power steering and aluminum wheels.
Prowler_Compact
The Prowler 500 has 7.5 inches of travel front and rear and a tilting bed that can hold 500 pounds. It comes with steel wheels and without power steering. The Prowler 1000 XT EPS is $15,299, the Prowler 700 XT EPS is $13,999 while the Prowler 500 comes in at $9499.
PROWLER HDX
HDX700XT
Arctic Cat’s more utility focused Prowler HDX UTVs have contoured seating for three, a transformable tilting cargo box that converts to a flat bed and side storage compartments under the bed. Beds on the HDX 700 XT can hold 1000 pounds and the bed on the 500 XT can carry 600 pounds. The suspension offers 10 inches of travel front and rear. Air adjustable Fox Float rear shocks compensate for heavy loads on the HDX 700 XT and HDX 700 Crew XT.
HDXCrewXT
With a wheelbase 31 inches longer than the standard HDX models, the new Prowler HDX 700 Crew XT features comfortable seating for six. The HDX Crew 700 also comes with the transformable tilting cargo box. The HDX 700 XT is $14,499, the HDX 700 Crew XT is $15,499, and the HDX 500 XT is $11,999.
MUDPRO 1000 LIMITED EPS, MUDPRO 700 LIMITED EPS & 1000 XT EPS
MudPro1000LTD
The 951cc, single overhead cam, 8 valve, V-twin Mudpro 1000 Limited EPS and single cylinder, 695cc, single overhead cam, 4 valve Mudpro 700 Limited EPS are made for mud competition. The 1000 features an extended wheelbase. Both models include snorkel engine and transmission intakes, Maxxis Zilla tires on beadlock wheels, heavy duty bumpers and winches. The 1000 is $11,999 and the 700 is $10,499.
Alterra1000
The 1000 XT EPS joins the power of Arctic Cat’s 951cc V-twin to a standard wheelbase sport utility ATV chassis. It’s $11,499.
ALTERRA 4×4 ATVS
Alterra ATVs are available with 695cc liquid cooled, 443cc liquid cooled , and 366cc air cooled single overhead cam four valve engines. The two rider Alterra TRV ATVs are available with a 951cc V-twin, the 695cc single or the the 443cc single. All Alterra 4x4s come with spacious, comfortable ergonomics, fully automatic transmissions and independent front and rear suspension.
Alterra700XT
The Aterra 700 XT EPS comes with power steering, painted bodywork and aluminum wheels for $9999. Base Alterra 700s come with steel wheels and without power steering or painted bodywork for $8999. The Aterra 500 brings new generation Arctic Cat comfort and styling to this affordable 4×4. It’s $5999. Built on the same chassis as the Alterra 500, the Alterra 400 gives riders access to Arctic Cat features and comfort for $5499.
