EPA Releases Final Renewable Fuel Mandate for 2018
Even more ethanol coming soon.
The renewable fuels mandates released by the U.S. Environmental Protection Agency are higher than the 2017 levels and the 2018 levels the agency proposed in June, reported the American Motorcyclist Association.
The EPA’s final 2018 Renewable Volume Obligations call for 19.29 billion gallons of renewable fuel — primarily corn ethanol — to be blended into the nation’s gasoline supplies. That figure is higher than the 19.24 billion gallons the agency proposed in June and slightly higher than the 19.28 billion gallons required in 2017.
“It is disappointing to learn the EPA raised its proposed Renewable Volume Obligations for 2018,” said Wayne Allard, AMA vice president for government relations. “The decision goes against the agency’s promise to listen to consumers, who have indicated a low demand for higher ethanol blends. Forcing more ethanol into the nation’s fuel supply places motorcyclists at greater risk of misfueling their bikes.”
The EPA mandates continue to rise, even as cars become more fuel efficient and drivers travel fewer miles each year. Forcing more ethanol into fewer gallons of gasoline results in higher-ethanol blends for consumers.
Most gasoline sold in the United States contains 10 percent ethanol (E10), which all modern automobile engines and many motorcycle engines are built to accommodate. However, if the RFS requirements continue to be implemented, it will result in higher-ethanol blends-such as E15 (15 percent ethanol)-to become more prevalent at retail outlets.
An increase in the supply of E15 can lead to inadvertent misfueling-caused by blender pumps and confusing pump labels-by motorcyclists.
None of the estimated 22 million motorcycles and all-terrain vehicles in use in the United States is approved by the EPA to operate on ethanol blends higher than 10 percent. Using higher-ethanol blends in those vehicles is illegal and may cause engine and fuel system damage and void the manufacturer’s warranty.
The AMA also is concerned the increased reliance on ethanol could further reduce the amount of E0 fuel available. Since the distribution network for E15 and E85 is limited, fuel producers may be forced to reduce E0 output to stay within the EPA’s rule.
“The Renewable Fuel Standard has been broken for years, and Congress needs to reform the law to protect motorcyclists and the millions of consumers who do not want higher ethanol blends,” Allard said.
