First Look: 2015 Can-Am Maverick 1000 X MR
2015-Can-Am-Maverick-1000R-X-mr
For 2015, BRP takes the entry-level rec-utility segment by storm with the all-new 2015 Can-Am Maverick 1000 X MR 4×4. This machine features a new, class-leading, single-cylinder 38-hp, liquid-cooled Rotax 450 four-stroke engine, nestled in a similar G2 SST frame found on the larger-bore Can-Am Outlander 4×4 models. That is not all, the vehicle also includes an unprecedented, industry-leading, five-year extended warranty and numerous changes to make it the most affordable and value-packed CanAm Outlander ATV to date. A rear-mounted silencer, steel tubular racks, SACHS five-way preload adjustable shocks and Carlisle Trail Wolf tires on steel wheels are just a few changes. Power steering, alternate colors, larger magneto and cast-aluminum wheels are available on the CanAm Outlaner L 450 DPS model.
2015 Can-Am Maverick 1000 X MR Features
A hearty, single-cylinder, liquid-cooled Rotax 450 four-stroke offers unmatched power and performance for its class, while remaining both reliable and efficient. Along with supplying an industry-leading power-to-weight ratio, the 38-hp Rotax offers electronic fuel injection to remain as efficient for work and play. Regardless of temperature or altitude, EFI ensures optimal performance from the engine at all times. Progressive throttle control means the power remains manageable in slow-speed circumstances or during quicker riding situations.
CVT transmission
The Continuously Variable Transmission (CVT) means you’re always in the correct gear. For ease of use, you can count on the integrated engine braking reduce speeds when going downhill. Dual-room, no-tools air box Like all models with the SST G2 design, the Outlander L 450 has a dual-room, no-tools air box that is elevated and centralized for unmatched efficiency. Its dual-room setup works diligently to capture and trap dirty air and then effectively transfer clean air to the engine for optimal performance.
