HMF Lines Up The Honda Talon
HMF releases exhaust solutions for the Honda Talon.
The HMF exhausts for the Honda Talon 1000 R/X are available as a Dual Full System in the Performance and Titan series and a Slip-On in the Titan series. All available HMF exhausts take advantage of HMF’s superior engineering to produce unmatched durability, sound, power and torque. All systems retain the OEM oxygen sensor for optimum drivability.
Dual Full System – Performance & Titan Series
The 4″ aluminum Performance Series picks up 9 hp and 4 ft-lbs of torque while reducing the weight of the entire exhaust system by 10 lbs. The 5″ stainless steel Titan series is available in our QS (quiet) and XL (loud) internal core design.
The Titan series reduces the weight of the entire exhaust system by 5 lbs. The Performance and Titan XL Full systems are 6 dB louder than stock at idle, while the Titan QS is 4 dB louder than stock at idle. The dual center exit design protects the entire system within the frame of the vehicle and produces an amazing sound and look. $899.95 to $1024.95
Slip On System – Titan Series
The 5″ stainless steel Titan Slip On System retains a similar layout as the stock exhaust while still retaining the signature HMF design.
The Slip On System picks up 3 hp and 3 ft-lbs of torque and reduces the weight of the exhaust system by 9 lbs. The Titan XL Slip On system is 5 dB louder than stock at idle, and the Titan QS is only 2 dB above stock. $499.95
Fuel Tuning is absolutely required when installing an HMF Exhaust on this machine. Failure to tune the engine can cause excessive damage to the exhaust system and engine, while voiding the warranty on your exhaust and possibly on your machine. (check with local dealer). See the HMF tuning settings for the proper fuel tuning solution on your machine.
More info.
