It’s Official: Meet The 2020 Kawasaki KRX 1000
Get ready to experience adventure like never before. The Kawasaki Teryx KRX 1000 sport side x side is engineered for high adrenaline adventures and conquering the toughest terrain. Powered by an all-new 999 cc parallel twin engine that is paired with a CVT transmission and centrifugal clutch, the Teryx KRX 1000 has the power to tackle a whooped-out trail and the torque to conquer the most technical rock crawling section. A high-rigidity frame with integrated Roll Over Protection Structure (ROPS) positions the wheels as far apart as possible to provide a sure-footed stance, superb cornering and straight-line stability.
Obstacles on the trail are soaked up by FOX 2.5 Podium LSC shock units, which combined with long suspension arms give the KRX 1000 the longest suspension travel in its class. A roomy cockpit features half doors and adjustable high-back bucket seats to deliver outstanding ride comfort no matter the terrain. The all-new Teryx KRX 1000 side x side is engineered to provide Kawasaki’s dependable, proven performance to outmuscle anything that stands between you and an adventure of a lifetime.
SPECS
POWER
Engine4-stroke, DOHC, 4-valve parallel-twin, liquid-cooled
Displacement999cc
Bore x Stroke92.0 x 75.1 mm
Compression Ratio11.5:1
Maximum Torque76.7 lb-ft @ 7000 Rpm
Fuel System DFI with two 50mm throttle bodies
Ignition TCBI with electronic advance
Starting System Electric
Transmission Automatic CVT with centrifugal clutch (H,L,N,R)
Final Drive Selectable 2WD/4WD with locking front differential, shaft
Engine Braking Yes
CAPABILITY
Front Suspension / Wheel Travel Double wishbone, FOX 2.5 PODIUM LSC shocks with piggyback reservoir, fully adjustable preload, and 24-position adjustable compression damping/18.6 in.
Rear Suspension / Wheel Travel4-link trailing-arm rear suspension, FOX 2.5 PODIUM LSC shocks with piggyback reservoir, fully adjustable preload, and 24-position adjustable compression damping/21.1 in.
Front Tires MAXXIS Carnivore 31 x 10.00R15 8PR
Rear Tires MAXXIS Carnivore 31 x 10.00R15 8PR
Steering Electric Power Steering (EPS) / rack-and-pinion
Front Brakes Dual hydraulic discs with two-piston calipers
Rear Brakes Dual hydraulic discs with single-piston calipers
Ground Clearance 14.4 in
Fuel Capacity 10.6 gal
Turning Radius 19.4 ft
Cargo Bed Dimensions (LxWxH) 14.6 x 33.1 x 9.1 in
Cargo Bed Capacity 351 lbs
Load Capacity 781 lbs
Seating Capacity 2
Towing Capacity N/A
Lighting(4) LED headlights, (2) LED taillights, LED stoplight
DETAILS
Frame Ladder type, tubular steel
Overall Length 130.1 in
Overall Width 68.1 in
Overall Height 75.0 in
Curb Weight 1896.3 lbs (1898.5 CA)**
Wheelbase 98.8 in
Instruments Multi-function digital meter with bar-style tachometer (2 display options), digital speedometer, bar-style fuel gauge, gear indicator (L, H, N, R), Power Mode, driving mode (2WD/4WD/4WD+Diff Lock) indicator, Economical Riding Indicator, clock, odometer, dual trip meters, hour meter, water temperature, digital battery gauge, bar-style CTV temperature, seatbelt warning lamp, oil warning lamp, engine check lamp, water temperature warning lamp, neutral indicator lamp, reverse indicator lamp, parking indicator lamp, EPS warning lamp, and CVT belt warning lamp.
Wheel Type Alloy with bead-lock wheels
Color Choices Lime Green/ Metallic Onyx Black, Metallic Moondust White/ Metallic Onyx Black
Warranty 6 months
Kawasaki Protection Plus (optional) 12, 24, or 36 months
For more, click here.
You must be logged in to post a comment.
