Kawasaki 2026 MULE PRO 820 Models
The versatile 820s are here for 2026.
For more than 30 years, Kawasaki MULE side x sides have been notorious for their exceptional performance in both work and recreation. The Kawasaki MULE PRO-FX 820 and MULE PRO-FXT 820 lineup represents the strength of MULE engineering, offering an 812cc three-cylinder engine, four-wheel independent suspension and one-ton towing capacity. These MULE vehicles are designed to tackle any challenge and are backed by the Kawasaki STRONG 3-Year Limited Warranty.
MULE PRO-FX 820 EPS
The MULE PRO-FX 820 EPS comes equipped with a powerful 812cc engine and cast aluminum wheels so you can carry bigger loads in confidence. The MULE PRO-FX 820 cargo bed measures 54.1 x 53.3 x 11 inches and supports up to 1,000 lbs., making it large enough to fit a standard size pallet.
MULE PRO-FXT 820 EPS
If accommodating a higher volume of passengers is on your list, the 2026 MULE PRO-FXT 820 EPS comes with all of the great features found on the MULE PRO-FX 820, with the added bonus of a second row that easily converts this MULE from a three-person to a six-person workhorse using the innovative Trans Cab system. Designed with heavy-duty tasks in mind, this robust vehicle effortlessly handles both substantial loads and transporting a full crew. In its three-passenger mode, the cargo bed measures 42.7 x 53.6 x 10.9 inches and supports up to 1,000 lbs. In six-passenger mode, the bed measures 22.0 x 53.6 x 10.9 inches with a capacity of 350 lbs.
KAWASAKI GENUINE ACCESSORIES
Owners can personalize their MULE PRO to meet their needs, with over 90 Kawasaki Genuine Accessories to choose from, including new accessories like front and rear A-Arm guards, heater, WARN® VRX 45 and VRX 45-S winch kits, bed lift kit, LED headlight set, windshield washer and wiper harness, and returning accessories including a universal ignition switch, headlight and taillight guards, KQR cargo box, audio system and plow mount.
Several packages are also available including utility packages and protection packages which include many of the great accessories listed above.
To top it off, all Kawasaki MULE side x sides are confidently backed by the Kawasaki STRONG 3-Year Limited Warranty.
2026 Model Variations
Kawasaki MULE PRO-FX 820 EPS
Color: Timberline Green, Dark Royal Red
MSRP: $15,199
Availability: Early 2026
Kawasaki MULE PRO-FXT 820 EPS
Colors: Timberline Green, Dark Royal Red
MSRP: $16,999
You must be logged in to post a comment.
