Kawasaki Unveils 2025 MULE PRO-FX 1000 HD
The MULE PRO-FX 1000 HD returns in 2025 bringing Kawasaki STRONG capability combined with class leading comfort.
Powered by a Kawasaki-built 999cc liquid-cooled, 4-stroke parallel-twin engine that delivers significant power and torque as well as increased top speed that makes it Kawasaki’s fastest MULE ever. Complementing the engine is a sturdy chassis with MULE PRO series performance and self-leveling suspension that adjusts to help keep the vehicle level when fully loaded.
2025 KAWASAKI MULE PRO-FX 1000 HD HIGHLIGHTS:
9 inches of front suspension travel and 10 inches of rear suspension
9 inches of ground clearance
Self-levelling rear suspension
Substantial cargo bed and 2,000-pound towing capacity
Kawasaki STRONG 3-Year Limited Warranty
MULE PRO-FX 1000 HD Edition
The MULE PRO-FX 1000 HD Edition side x side is a powerful, high-capacity, three-passenger vehicle with a long cargo bed that’s built to take on the most demanding days. With dependable power and exceptional all-day comfort, this rugged side x side is the perfect companion for work and play and provides the reliable capability to finish the job.
It features Kawasaki’s first self-levelling suspension that helps keep the vehicle level when carrying a heavy load. This allows the weight to be spread more evenly and benefits both handling and braking performance. The system uses the mechanical energy of the shock action to pump the oil as the vehicle is moving. The system is automatic and does not require any electronic systems or a compressor and the normal suspension movement over a regular road surface provides sufficient pumping action to level the vehicle. When the load is removed and the shocks extend above the optimum level, a release circuit is exposed, allowing the oil to return to the reservoir and the ride height to slowly decrease to its optimum level.
The MULE PRO-FX 1000 HD Edition side x side comes equipped with a rear bumper for extra protection and a tilting cargo bed that uses a switch-operated hydraulic lift for added convenience. The cargo bed switch is located below the cargo bed on the left side of the vehicle. The cargo bed measures 54.1 x 53.3 x 11-inches and has a load capacity of 1,000 lbs. The MULE PRO-FX 1000 HD is available in Firecracker Red colorway and is confidently backed by the Kawasaki STRONG 3-Year Limited Warranty.
