Lightfoot Track system
Setting
the Stage
for
traction!
LightFoot
Track
System
 undefined
Track up your ATV with LiteFoot™ ATV Rubber Tracks For the 4WD ATV owner who thinks tires are just not enough to get you out to your favorite outdoor location, we introduce LiteFoot the ATV rubber track conversion system. LiteFoot tracks bolt onto your ATV in place of the wheels, giving your ATV, “tank like” mobility over most any terrain.
This easy-to-install, patented ATV rubber track conversion system can turn most any 4X4 ATV into a fully tracked 4 “track” drive, all terrain vehicle in about the same amount of time it takes to change wheels.
LiteFoot earns its namesake by delivering an average 3/4 psi surface pressure, this provides incredible flotation over soft terrain, like sand, snow and mud. This low ground pressure does not sacrifice traction, with an average 1320 square inches total surface contact, LiteFoot gives you unbelievable traction with minimal ground impact.
The exclusive LiteFoot SCS™ System, a ground-hugging track suspension, adjusts to the terrain without the loss of track tension, forming to the terrain and maintaining traction.
Can’t quite “get over” the idea of having an ATV with tracks? With LiteFoot tracks installed on your ATV you can “get over” a lot of obstacles. Gaining an average of 4 inches in extra clearance, most sport utility ATVs will easily clear 12 inches of ground clutter. Along with added clearance, you gain a wider and longer wheel base lowering your center of gravity for more ride stability.
For work or play, great for hunting, exploring and weekend trail riding. LiteFoot tracks can be enjoyed all year round in mud, snow, sand, through swamps and rough terrain, LiteFoot ATV tracks will get you out there and back again! 98 MSRP plus shipping and handling.
