Massimo Warrior 800: The UTV Arnold Would Own
Mean grill.
Massimo has a pretty nice line of UTVs but their all new Warrior 800 is certainly doing its part to separate itself from the rest of the pack.
Looking like a Hum-V and boasting the cool 3x seating configuration, the $12,999 UTV is available now and comes spec’ed as follows:
Engine & Drivetrain
• Engine Type: Four Stroke 2 Cylinder V-Twin
• Displacement: 800cc
• Horsepower: 60 HP
• Cooling: Liquid Cooled
• Transmission/Final Drive: Automatic CVT P/R/N/L/H, Shaft Drive
• Drive System: 2WD/4WD, Locking Differential
• Fuel System: Electronic Fuel Injection (EFI)
Chassis
• Front Suspension: Independent Dual A-Arm
• Rear Suspension: Independent Dual A-Arm
• Front Tires: AT 27 x 9-14
• Rear Tires: AT 27 x 11-14
• Front Brakes: Dual Ventilated Hydraulic Disk Brakes
• Rear Brakes: Dual Ventilated Hydraulic Disk Brakes
• Wheels: Aluminum
Dimensions & Capacities
• Vehicle Size (L x W x H): 131.5 in x 70 in x 77 in
• Wheelbase: 91.5 in
• Ground Clearance: 12.5 in
• Cargo Bed (L x W x H): 42.5 in x 65.5 in x 10.25 in
• Cargo Bed: Hydraulic Piston Dump
• Towing Capacity: 1,500 lbs
• Cargo Bed Capacity: 500 lbs
• Fuel Capacity: 12.7 gallons
• Seat Height: 34.5 in
• Dry Weight: 1,830 lbs
Additional Features
• Electronic Power Steering
• Warranty: 1 Year Parts & Labor
• Battery: 12V 35AMP
• Assembled in Texas, USA
• Instrumentation: Digital Display, Speedometer, Odometer, Tachometer, Hour Meter, Gear Indicator, 4WD Indicator, Differential Lock Indicator, Trip Meter, Headlights (High/Low), Turn Signals, Fuel Gauge, Hi-Temp
