MB Quart Offers Options You Can Hear & Feel
8_Full
Put your music, right where you can hear it – and FEEL IT. Bring the sound with you with this MB Quart designed, all-in-one speaker solution that mounts easily and securely with low profile clamp-on mounts which maximizes visibility. The Polaris Sound Bars feature midrange/midbass drivers, two dedicated tweeters and an integrated amplifier designed to play loud. You can play music directly from your device using either the provided 3.5mm wired input or through the MB Quart Bluetooth Connect feature. Large push buttons allows you to control the unit while on the go, even with gloves on. This unit works great as a stand-alone audio solution, or you can make it part of a larger, full-sound experience by adding an optional sub-woofer, audio pods and more. Durable extruded aluminum housing finished in black will provide years of trouble free sound.
4 & 8
4_Full
The Polaris Sound Bar 4 utilizes two active 3 inch high-energy drivers with poly composite cones with Butyl rubber surrounds to produce great sounding music while being protected against the elements. The high frequency drivers are 1 inch pure Titanium tweeters with Neodymium magnets that are a more powerful magnet than ferrite magnet yet smaller in size. It all culminates in developing tremendous volume with minimal distortion.
The Polaris Sound Bar 8 is similar to the Sound Bar 4, only bigger and better. The speaker utilizes four active 3 inch high-energy drivers. Additionally, the Sound Bar 8 uses two 3 inch passive radiators which look like speakers, but are in fact an additional cone that mechanically doubles the cone area of the active speaker to develop additional low frequency response. The tweeters are also the same, 1 inch pure Titanium tweeters with Neodymium magnets. Some music junkies will find a way to install one of each. Front and rear perhaps??
It Just Fits
With the included hardware, the Polaris Sound Bar speakers will fit perfectly on your ATV, RZR or ACE. The Sound Bars were designed to be mounted between the visor clips and will not impede sight lines. With the oversize rubber buttons, the unit is easy to operate even when wearing riding gloves.
Graphic_Full
Mounted: Solid & Flexible
The innovative mounting system for the Polaris Sound Bars is solid and versatile because it was engineered with a Focused Mass Aluminum Structure to the Polaris demands for strength. The mounting system includes two sizes of bushings for 1.5 inch or 1.75 inch ROPS (Roll Over Protection System) mounting diameters.
Big Power
The Polaris Sound Bars by MB Quart are designed with a powerful 100 watt amplifier that is integrated into the enclosure.
Bluetooth Connect
MB Quart has developed the Bluetooth Connect, which allows a BT enabled device to be paired with the Sound Bars quickly and securely. The Bluetooth range is 32 feet or 10 meters.
WATERPROOF BLUETOOTH SPEAKER
bluetooth-speaker-sportsman-xp-hero-full
Imagine a compact, portable Bluetooth speaker with a 12 hour battery that easily connects to a Bluetooth enabled device and mounts on a RZR, Ranger or ATV like the SPORTSMAN or ACE. Imagine no more, MB Quart and Polaris have done it and it is good.
Waterproof Bluetooth Speaker
Enjoy a personalized soundtrack everywhere you ride by installing this Waterproof, Bluetooth Audio speaker on your Side by Side or Off Road Vehicle. This audio system, designed by MB Quart, mounts quickly, easily and securely to the handlebars, attaches to the roll cage or in the dashboard storage area and provides powerful, rich and high-quality audio as you ride. This portable audio unit can be easily removed for use in your garage, house, boat or camper. This self-contained audio unit has an internal rechargeable power source, and does not require a battery connection or draw from the vehicle’s electrical system.
It Just Fits
With the included hardware, the Waterproof Bluetooth speaker fits perfectly on RZR, Ranger, SPORTSMAN or ACE. Check with your local Polaris dealer or follow these links for your bike to the Polaris website.
Small Size. BIG SOUND
MB Quart Bluetooth speakers are engineered for Polaris to deliver maximum volume and deep bass into a small portable speaker.
RZR_Full
Loud & Clear
This speaker plays louder and delivers more power with a built-in high power amplifier that operates at higher voltage without sacrificing sound quality.
Bluetooth Connect/ Simple Pairing
Whoever brings the best music can be the DJ. Bluetooth Connect allows the Bluetooth Speaker to easily connect BT enabled devices and puts the music right at your fingertips, or the passenger’s, if the terrain demands 100% focus from the driver.
Secure Simple Pairing from MB Quart provides a quick and secure wireless connection between your Bluetooth enabled device and the speaker. This reliable connection is impervious to outside interference, providing a lock-tight connection to your audio system. The Bluetooth range is 10 meters or 32 feet.
Phone Control
The Polaris / MB Quart bluetooth speaker features AVRCP technology which allows control of play/pause and volume from the speaker or from your device.
Full Power
The Polaris / MB Quart bluetooth speaker includes a 110v adapter for quick charge of the QUBFour battery. Apple users can view the battery status on the screen.
Hardware
Dual Source/ Additional Input
The Polaris QUBFour features Dual Source technology allowing two devices to be paired to one speaker. Go between tablet and phone or two different phones without the need to reconnect. The speaker can be connected to play audio via the input jack with a 3.5mm audio cable included. There is no USB connection on this speaker.
For More Information:
Soundbars
Bluetooth Speaker
