Meet the UTV Schwarzenegger Would Drive
You’d be forgiven if, at first glance, you happened to mistake the Massimo Warrior 700 for some kind of top secret military prototype. Or a prop from Arnold Schwarzenegger’s next film.
It turns out the Warrior 700 is a recreational side-by-side available to anyone- enlisted or otherwise. It uses an all steel body built on a sporty, 65-inch wide Massimo Militia chassis with independent front and rear suspension (piggyback reservoir shocks).
Powering the machine is a 686cc, single cylinder, single overhead cam, four-valve engine good for 34 horse. It weighs in at 1,980 pounds and retails for $12,995 pretty loaded.
Check out their official site here for more or to locate a dealer.
