New UTV Phone Mount from Rokform
Built for the demands of the UTV environment.
Finally, a heavy duty UTV mount that’s built for heavy duty UTV use. Designed to mount onto any 1.75” to 2” roll cage, the Pro Series UTV Mount is THE heavy duty mounting solution for UTVs. Built with aircraft grade aluminum and stainless steel hardware, the Pro Series UTV Mount uses a dual locking system to securely hold smartphones through the sharpest turns, steepest climbs, and rugged terrain. With four points for adjustment, drivers of every height can quickly and easily find the perfect viewing angle for their smartphones. The UTV Mount locks onto most Rokform collections (Rugged, Fuzion Pro, Crystal), but can also be used with the Universal Adapter.
Exceptional Adjustability: 4 points of adjustment for optimum viewing angle
Superior Materials: Made with CNC machined aircraft grade aluminum and stainless steel hardware
Versatile Fit: Mounts onto 1.75” – 2” Roll Cage
Dual Locking System: Utilizes RokLock twist lock system and magnetic technology for safe and secure mounting
Works in both portrait and landscape modes
Designed and assembled in California
Includes Lanyard
The Pro-Series UTV Mount is currently on Pre-Order and is expected to ship November 16, 2018 though your credit card will be charged at the time that your order is placed to hold your spot in line. Shipping is free over $39
