Polaris Xpedition Gets HCR Suspension Kit
The Xpedition gets some aftermarket suspension love.
If you’re not familiar with HCR, these guys develop high-quality suspension kits for just about every performance SxS on the market today.
Their latest kit targets the all-new Polaris Xpedition.
Looking to take your Polaris Xpedition to the next level? Then look no further. The HCR Xpedition Mid travel kit features a 8″ wider stance to keep you stable and safe on any trail. Up to 18″ of ground clearance with the use of 35″ tires to clear over large obstacles. This 100% American made product is made to tackle any and every terrain and turn your Xpedition into an even more overland capable machine. The front a-arm lower shock mount design offers a more stable front end feel when driving on and offroad.
*First batch ETA end of December/ early 2024, Inquire within our sales department for lead times*
Features
Clears 35″ tires with up to 18″ of ground clearance
Easy 100% bolt on, no cut, no drill installation
8″ wider stance over stock track width to improve stability dramatically, improves safety, and gives the driver the confidence to push their Xpedition to the next level.
Lower shock mount front a-arm design
High clearance front and rear a-arms
Made out of HCR proprietary alloy, 30% stronger then chromoly steel.
Proudly Made in the USA
Kit Includes
(4) Front A-arms
(4) Rear A-Arms
(4) Axle Bars
(2) Tie Rod Extensions
Hardware pack
*This kit will require a spring upgrade, spring rate dependent on overall weight of Xpedition build*
The Xpedition kit can be studied further or purchased directly here.
About HCR
HCR’s proprietary billet slot and tab design and catacomb boxed arms are built to withstand the vigorous beatings of off-road riding while achieving the optimal combination of strength and appeal. Every external weld is an internal plate structured into the design. All parts are Fiber laser cut and CNC bent for precise fit and finish. An intensive process is used during each design to simulate and refine the new geometry to match the characteristics of the stock suspension while increasing suspension travel. Critical measurements are verified, such as ball joint angle, CV joint angle, and clearance to surrounding parts to ensure no binding or interference. All products are hand tig welded by seasoned craftsmen. The quality fit and finish, ease of installation, and top shelf performance of these kits are what sets HCR Racing apart from the competition. No kits are released to the public without numerous hours of vigorous testing in the rocks, desert, and dunes for true dual sport application.
