Power Tank
With the tank in the mounting bracket it can be mounted anywhere you have space. It’s small enough to be mounted on an ATV rack or in a vehicle. We found that it fit well under the rear seat of an extended cab truck. It’s everything you need all in a small convenient package!
The first step is to have the tank filled. You need to remove the handle and regulator and have it filled at your local welding shop. It costs about each fill. With the tank, regulator, handle, and 10 pounds of CO2 it weighs in at just less than 28 pounds. Advanced Air sells a digital gauge to weigh the tank to make sure you get a full 10 pounds and to see how much you have left after it’s used.
We were truly impressed with the power and portability the Power Tank has to offer!
If you ever need a high pressure air system miles from home the Power Tank is the only thing to consider!
