Primal Speed Gear Thumb Throttle
Primal
Speed Gear
Thumb Throttle
 undefined
undefinedIt was near the end of a 5-hour trail hammering and I had acquired “thumb pump syndrome”–a piddly phenomenon having the distinguishing characteristic of making your thumb unable/unwilling to apply more than a quarter throttle. Racers and recreational riders alike suffer from “thumb pump” and is more commonly found on long and rough rides. Your thumb muscles become so weak from overuse on a stiff throttle system that it’s difficult to apply the throttle and even more difficult to apply it with any modulation. The above incident was the deciding factor in switching to a twist throttle even though my preference on an ATV is a thumb throttle.
The Product
    Normally you have two choices. Convert to a twist throttle or adjust the thumb throttle a little by spinning the housing on the bars and living with its shortcomings. Now there is another choice–an adjustable thumb throttle by Primal Speed Gear called The Nibby. This trick-looking piece of CNC-machined aluminum replaces your stock thumb lever allowing you to adjust its position anywhere from in front of the grip to behind the grip. The machined aluminum, rubber coated thumb area and high quality fasteners make it an attractive replacement.
undefinedInstallation
    Installation was very easy and took less than 5 minutes on our ’86 250R test machine. You remove the throttle housing cover, bend the lock tab and remove a 10mm nut that allows the thumb lever and shaft to slide out the bottom as one piece. The replacement shaft is inserted from the bottom and fastened with the 10mm nut and lock tab. The new lever is then installed and tightened at the desired position with two Allen pinch bolts. We settled on an adjustment a little closer to the bars than the stock lever. The throttle housing cover is replaced and you’re roosting.
Ride Test
undefined        Our ride testing consisted of twisty, rocky trails ridden aggressively and fast–the perfect environment for “thumb pump” to rear its ugly head. Sitting or standing, the throttle is equally comfortable and its position closer to the bars feels more natural and less fatiguing. The overall length of the lever is very close to the stock 250R part, so the travel and effort required remain about the same.
Conclusion
       The Primal Speed Gear Nibby is a high quality product and can make your riding more comfortable and enjoyable. Those with hands larger or smaller than average will appreciate the Nibby the most. It’s not a necessity, but it is a great choice if you’re having problems with your stock thumb throttle.        If you’re more into watching than riding, Primal Speed Gear has you covered with a great looking T-shirt.
Nibby Price: .95 + tax (in MI) and shipping
T-shirt : .95 + tax (in MI) and shipping
