Product Spotlight: Rhino USA Pro Tire Deflator Kit
There are no shortage of handy devices and solutions to getting air into our tires, but what about when it comes to letting air out?
There are times when lowering air to a given pressure on the trail is paramount or situations where thoroughly deflating a tire can be a time-consuming affair. Enter the Tire Deflator Kit from Rhino USA.
This all-in-one kit is designed to quickly air down while on the trail and it’s compatible with any Jeep, truck, car, RV & of course ATVs and Side-by-Sides.
Simply screw the brass connector onto the tire’s valve and pull back the collar to begin deflating. Slide the collar back into place and the beefy 2″ dial (glow in the dark) gauge gives you the pressure instantly.
The kit also includes replacement valve stem cores and the tool to remove and install them should you find yourself miles from civilization with a faulty valve.
We use it, we carry it and it works.
Best of all it’s coming from an American owned father/son Business who are so sure you’ll be impressed that if you aren’t 100% Satisfied for any reason, they’ll refund you in full.
We picked our up for $24.90 here on Amazon.
