QuadBoss Spot Sprayer Arrives For The Utility Set
We hear that when not racing, play riding, rock crawling or mudding an ATV, they can be surprisingly adept tools for work. Who knew?
All kidding aside, utility oriented riders have cause for celebration as the new Spot Sprayer from QuadBoss is about to be released. A revolutionary solution to small-scale spraying for ATV use, the Spot Sprayer is available in 25 or 40 gallon corrosion-proof polyethylene tanks. Ideal for the farm, ranch, home or business use.
The Spot Sprayer flows a remarkable 1.8 gallon per minute using a 12 volt SHURFlo pump that connects directly to the vehicle’s battery and is controlled by a toggle switch. Perfect for spraying grass and weed killer, insecticides, etc.
The Spot Sprayer system includes the pump, hand-wand and spray nozzle with 6 feet of hose and integrated drain for easy cleanup. The spray nozzle adjusts to reach 25 feet or a fine mist for up-close coverage. It can also be used in conjunction with QuadBoss Booms and Swing Away Booms, which are sold separately. Includes ratchet straps for mounting to your ATV or UTV.
o order QuadBoss products, contact your local authorized Tucker Rocky Dealer or visit QuadBoss’s website to find an Authorized Dealer near you. You can also follow the latest news about QuadBoss on Facebook. For product questions call 877-847-1558 or email at QuadBoss@QuadBoss.com.
