RadLites Flashers
FLASHERS
by Rad Electronics
NEW !!! RAD DUAL FLASHER Dual Sided Adjustable Flasher Will work for any RadLites LED Products: Billet Mount, T-Bracket, Panel Mounts, strips or other LED’s
From 2 to 10 RadLites (5 per side) Single LED’s, 4 Whip Lites or 4 Strips. 300ma max Per Side. The Flash rate is adjustable from a 1 second to pulse to a rapid stoble effect. Two outputs that alternate from side to side for a cool effect with you LED’s. Slowest flash rate will increase the more lights you add, for slower flash rates use less lights per flasher. Comes with 6″ wire leads, two #6 mounting screws and instructions. Small case size 1.5″ X 2.25″ (not including tabs) .80 thick. Can be easily waterproofed for any application. ??Questions please write or call Price .99 each
same as above with single outlet
NEW!! RAD FLASHER Single adjustable flasher Will work for any RadLites LED Products: Billet Mount, T-bracket, Panel Mounts, strips or other LED’s From 1 to 5 RadLites single LED’s, 3 whip lites or 2 strips 300ma max. The flash rate is adjustable from a 1 second pulse to a rapid strobe effect. Slowest flash rate will increase the more lights you add, for slower flash rates use less lights per flasher. Comes with 6″ wire leads, two #6 mouting screws and instuctions. Can be easily waterproofed for any application. Price .99 each.
RadLites.com
Call Toll Free: 866-945-9892
email us at rad@gbis.com
