Fushin 90cc starting problems
Old Sep 1, 2009 | 11:17 PM
rooster69's Avatar
Question Fushin 90cc starting problems
My 90cc fushin will not start. It has always started and run fine. It has a new high quality battery and is on a battery tender so the battery is good. When trying to start the machine the starter relay solenoid just clicks once each time you press the start button then nothing. I have another 110cc Fushin machine so I swapped the relay solenoid between machines and the part from the 90 works in the 110 so Im assuming its not the solenoid. Is there anything I can check with the starter? I took it out and everything looked ok other than it was a bit dirty and one of the springs behind the stator? magnet was pretty much gone. Would this cause it to not turn over? Ill look for a couple new springs tomorrow and try again. Any feedback is appreciated.
gdmclnh
Jun 13, 2015 05:32 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
