Joel:
Thanks a bunch for the reply. I'm laughing and sighing relief at the same time. Looks like we've both been there done that with everything you mentioned. Keith |
Keith, keep an eye on the tire air pressure as well. Mine were inflated rock hard from the factory. I aired them down, but a bit too much. A few weeks ago I snowblow'd a huge track (2ft of snow) out back for the kids to zip around in. I zoomed around the track a few laps to get the machine warmed (think of fat guy on a little quad here). All of sudden things didn't feel right.. I blew the right rear tire right off the rim!:eek: That was a real bugger to reseat/rebead in my 20degF garage. Had to soap up the bead and tighten a strap around the circumference of the tire to get it to seat.
Joel |
Originally Posted by craigandjacob
(Post 2905917)
has anyone ever just cut out part of the right panel for easy access to dipstick im going to try that it beats pulling guard off everytime
Is the ata125 supposed to have a charging system to maintain the battery? If so, mine sure doesn't work. The battery dies after just a couple hours of use.
Originally Posted by aaronrkelly
(Post 2902985)
Also I believe that charge is NOT a automatic charger. If you just leave it on the charger you will cook the battery. Im a big fan of battery maintaniers......and a cheap one can be bought at WalMart for $20 or Harbor Freight for $8.
Originally Posted by chamwster
(Post 2988588)
For long periods of sitting, I'll throw my cheap Harbor Freight Tools trickle charger on it. You can get them for around $7. Joel |
Thanks Joel
Thanks for the reply Joel. It is a big help to know it's supposed to be charging.
