TaoTao 150E Brake Line
I have cracked my rear brake line. I know generally how to fix it but not specifically. I have orderded the new line. I know that it uses DOT4 fluid. I know that I have to bleed the line. What I don't know is how to bleed it. Can someone give me some pointers?
Thanks
Supergroomer
Thanks
Supergroomer
bleed it just like you do on a car just pump up the brake lever and hold it then bleed it when you release the lever you will need to check the fluid level each time because the reservoir is very small.if you run it out of fluid you have to start over. watch the bleeder each time you bleed for air once you get all of the air out it will shoot fluid out in a smooth stream each time you bleed the brake lever should get stiffer. just holler at me if you have any problems.
Steeldon
Sep 9, 2015 09:38 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
