Totally new to the group and ATV's
Old Jul 5, 2010 | 05:58 PM
sspatriot's Avatar
Default Totally new to the group and ATV's
This may be a dumb question, but when referring to the pilot jet, there are small holes that go through the side of it, I believe there are three all together. They are all clear. Should there be a hole that goes through the pilot jet lengthwise?
Also, I don't believe the throttle attachment was ever secured to the top of the carbuetor properly.
Please advise,
Steve
Old Jul 5, 2010 | 08:11 PM
outofline's Avatar
Yes there will be a hole lengthwise as well. Hold it up to a light source, you should be able to see through it if it's not clogged!
Old Jul 7, 2010 | 04:29 AM
sspatriot's Avatar
I can't seem to get that hole cleared on the pilot jet that goes through its length. I've tried boiling it in hot water, carb cleaner (by gumout) and MEK. I've tried shoving avionics wire through it and it won't give. Is it time to replace? If so, where do most people go for parts like this for a Kazuma? Please advise.
Regards,
Steve
Old Aug 28, 2010 | 06:13 AM
sspatriot's Avatar
Default PZ19 Carburetor Repair Kit
Hi,
Well do to the extended heat wave here this summer, I went out and purchased a carburetor repair kit for this PZ19 carb. Just yesterday, I finally took a day off to give this thing some attention... The kit came with a new air/fuel mixture screw (flathead) should I be able to replace that screw? I tried backing it out of the carburetor with a regular slotted screwdriver, however, it seemed very tight, so I left it in there and did not replace it.
Please advise,
Steve
Old Aug 28, 2010 | 11:43 PM
  #15
Mr.Firemouth's Avatar
You have a factory 19mm carb. If the jets clogged then the float needle/valve will soon act up too. It is much easier to replace these carbs with a slightly larger carb and remove the air box and use a uni-filter.
I will send you a PM with links to help you....
A slightly larger carb and uni-filter air cleaner will offer more performance also.
Old Aug 29, 2010 | 06:40 AM
  #16
sspatriot's Avatar
Thanks. This was the only screw I wasn't able to replace because I was afraid it might break off completely so I stopped there. I would put a picture of it on this post, but I haven't figured out how to do that yet.
Old Aug 29, 2010 | 07:00 AM
  #17
You can use an offsite image host like Photobucket.com and then copy the [img] codes to this forum with copy/paste.
You can also use the "go advanced" button at the bottom of this post, then go to "manage attachments" and then upload an image from your computer.
If you need more help just LMK>
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
kampswas
Sep 23, 2015 05:05 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
