110 suni gokart
Old Aug 7, 2010 | 06:27 AM
bostonadams2's Avatar
Default 110 suni gokart
my motor will start and idle but when the throttle is engaged the motor will not pull the weight of the cart. what may be the problem? is it possibly the voltage regulator,the sparkplug coil or a carb. issue? please give me all possible reasons so i can troubleshoot the issue. thanx,bostonadams2
Old Aug 8, 2010 | 11:18 PM
Jaster94's Avatar
if the motor revs up, check your clutch. does it smell burnt? the clutch may need adjusting. refer to your owner's manual. if you don't have one, holler, we'll see what we can come up with. sorry, not familiar with sunl. i presume the 110cc is a forward/reverse only, right? not a L/H/R?
Old Aug 14, 2010 | 07:59 AM
it is a forward only. it has no reverse.
Mark0524
1) Engine problems..
Mar 2, 2015 02:59 AM
eroc1313
Nov 24, 2014 12:39 PM
jorke
Jan 13, 2006 07:26 AM
QUADRUNNERMIKE
Oct 24, 2003 01:58 AM
