Baja QJ 250 ATV Gearbox
Old Sep 30, 2012 | 07:52 AM
  #21
SCRAMIN's Avatar
so i bought one of these this weekend with guess what a blown trans thought would be easy to fix finding parts will be problem so it does lookk like i faired a little better mine the bearing just went where can i find the parts list so i can make sure get it all back toegther local bearing shop can get me the bearing i just need to make sure nothing else is broke
Old Nov 2, 2012 | 06:30 PM
  #22
evtraveler's Avatar
Default QJ250cc baja GEAR BOX
Originally Posted by HeatherSchmidt
found the gearbox case
Hey HeatherSchmidt-- where did you find the gear box CASE ??? pls let us know !!! How much did it cost ?? Pls fill us in on the details, and WHERE you got it!!
Thanks
Old Nov 2, 2012 | 06:39 PM
  #23
evtraveler's Avatar
Hey Heather, where did you find the CASE ?? How much did it cost ? Let us know the details. Do they have MORE CASES for sale ??Did you need any GEARS?? How "bout the bearings? where did you find them ? Pls give us the details !!
THANKS
Old Apr 1, 2016 | 05:23 PM
  #24
BruceBruce's Avatar
Originally Posted by cphillips
leonaard graham,
Is it the gear inside the gear reduction box which I guess is closer to the cvt belt or the gear in the actual fwd/rev box bolted to the output shaft of the reduction box? If you can send a pic of the gear I might have it, I did away with the fwd/rev box and just have fwd now with a custom made sprocket on the splines of the gear reduction output shaft. So I have the gears from the fwd/rev box just two of them (not sure exactly which ones) are missing teeth. If I have the gear I would gladly send it to you for postage. Also I have a question for you, could you get me a pic of the wires going into the cdi box, I desperately need this to get mine running again. The plug that goes into the box fell apart and I dont know what color wires go where on the cdi box. There is five wires and one unused plug. If you cant get a pic of it just telling me in what order they go on would be great.
Let me know,
Cole
I know it's been a long time since this was posted but I need the gears for this gearbox like an escomo needs clothes I'm willing to pay whatever if u still have sitting around
Old Apr 1, 2016 | 08:01 PM
  #25
evtraveler's Avatar
Default gear box for QJ 250 ATV
Hello, THANKS FOR THE REPLY, I need the whole gear box for this ATV, as the CASE IS BROKEN. Inside where the gear shaft fits into the case there is no bearing and the shaft cracked the gear box housing. Where there should be one !!
As I am traveling now, I post pics of the CDI BOX when I get back home.
Also here is pic of my broken gear box.
DO YOU HAVE ONE ??
Attached Thumbnails Baja QJ 250 ATV Gearbox-2010-09-08_11-26-51_70.jpg   Baja QJ 250 ATV Gearbox-2010-09-08_11-26-05_279.jpg   Baja QJ 250 ATV Gearbox-2010-09-08_11-26-38_445.jpg   Baja QJ 250 ATV Gearbox-brokenpartongearcase903.jpg   Baja QJ 250 ATV Gearbox-2010-09-08_11-27-34_159.jpg
Old Apr 1, 2016 | 09:16 PM
  #26
BruceBruce's Avatar
DO YOU HAVE ONE ??
Unfortunately mine did the same but before I noticed also tore up the drive gear taking out 7 teeth and took a tooth out of another started off with case cracking causing pieces of metal to get in the gears. But I have to ask will you sell me your gears
Old Apr 1, 2016 | 09:43 PM
  #27
BruceBruce's Avatar
I can say the manufacturer of the engine is linhai
Old Apr 1, 2016 | 09:48 PM
  #28
BruceBruce's Avatar
If anybody can get me the gears Please email me @ jr2014jr1994@gmail.com please summer is coming and this was my only hope to enjoy it now it's crap
Old Apr 3, 2016 | 12:00 PM
  #29
MPDano's Avatar
Absolutely impossible to get the gearbox. I have a sticky that shows my steps in getting mine welded. Didn't hold up after the first trip to the desert.
Old Apr 6, 2016 | 01:27 AM
  #30
BruceBruce's Avatar
Would you sell me your gears ?
