Changing Oil
Old Mar 7, 2011 | 10:35 AM
konefour's Avatar
Default Changing Oil
Can someone tell me what wt. of oil should be use in ATA-125 and 150's? Diesel oil? Also, how much oil should be used for the 125 and 150 in ounces?
Thanks!
Old Mar 7, 2011 | 02:39 PM
isovapor2112's Avatar
For the ATA-125, I use 15w-40 (Shell Rotella or Wal-mart "SuperTech"). I put 700ml in and that fills it up to the top mark on the dipstick. The diesel oil has no additives that would cause a wet clutch to slip. Others here use Valvoline 10w-40 without any problems. The key is to change the oil often. It is what keeps these little machines alive. As for the 150cc, I don't have a clue.
Old Mar 7, 2011 | 02:44 PM
Sorry I didn't see that you wanted ounces.
700ml = 23.67 ounces
Old Mar 7, 2011 | 06:22 PM
outofline's Avatar
I also use the 15/40 from wallymart, I would suggest never use 10/40 in anything, worst Viscosity ever! If your riding in real hot outside temps of say over 100deg I would switch to 20/50!
Old Mar 8, 2011 | 06:56 PM
OneTenCC's Avatar
Yep, the newer Taotao machines recommend 15w40 right on the machine's name-plate. The 110's and 125's do get pretty hot given you've got to force air over the engine to cool it, so a 40wt (or even a 50 like said) is a must.
The 150cc does a better job of cooling itself being fan cooled, but I still use a cheap 15w40 in it. Is there any 'cheap' oil anymore? It's all like 3-4x what it used to be.
Joel
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
