Want to blow up my tao tao! (kinda long)
My son has a Taotao 110 and here is what they say in thier FAQ:
The most common problems are going to be:
1. Carburetors: (10-15 minute replacement for someone who isn't a mechanic with just a screwdriver) . They have an anti corrosion agent to keep parts from rusting inside that sometimes will leak down into the bowl or tubes of the carb causing the floats or tubes to stick shut, usually a simple cleaning and emptying of the bowl fixes the issue, but if it doesn't DON'T WORRY we can ship you out a brand new carb for no charge while under warranty.
2. CDI boxes: (5-10 minute replacement for someone who isn't a mechanic with just a screwdriver) These are crucial to maintaining consistent starting power to your ATV. It's a small black box located under the seat of your ATV. Simply unplug the old CDI and Plug in the new one.
3. Ignition coils: (10-15 minute replacement for someone who isn't a mechanic with just a screwdriver)
Same story as with the CDI box, the ignition coil brings spark to your ATV or Go Kart. Another easy pop off/pop on fix with a screwdriver.
Hope this helps! Good luck!
