Jianshe 250 parts
Old Oct 22, 2011 | 07:25 PM
jianshe250's Avatar
Default Jianshe 250 parts
I'm selling several brand new part for a 250 Jianshe.
Here is a list of parts:
Gaskets, head, base, case, intake, exhaust
Seals, engine, rear axle
Centrifugal clutch, clutch disks, & basket
Pistons, complete cylinder head, timing chain & tensioners
2 pair of brake shoes
crankcase cover ( starter motor side )
starter relays, choke controller, indicator lights, headlights, on/off main switch
ignition coils w/spark plugs
Used transmission gear cluster
Reverse / forward gear dog
Old Oct 26, 2011 | 11:35 AM
blain's Avatar
Default brake hub
do you have a rear right hub to fit a 250 baja wilderness
Old Oct 26, 2011 | 06:34 PM
jianshe250's Avatar
No, I don't have any hubs.
I have diff housing parts minus the axles.
Old Dec 12, 2011 | 04:58 PM
jianshe250's Avatar
Still have parts available!
Old Dec 13, 2011 | 05:38 AM
blain's Avatar
Default to fit
do you no if any other atv hubs will fit the 250 bayo looks the same and some grillys one i don;t care about the brakes on it as long as the splines are the same i think there is 27 splines on it
Old Feb 20, 2012 | 07:56 PM
jianshe250's Avatar
For sale!
Old Jun 24, 2012 | 09:08 AM
jianshe250's Avatar
Jianshe 250 parts-dscf1687.jpg parts available !!
Old Jun 24, 2012 | 09:14 AM
jianshe250's Avatar
Old Aug 5, 2012 | 04:12 PM
jianshe250's Avatar
parts for sale!
Old Sep 6, 2012 | 08:04 AM
leonard graham's Avatar
how much for transmission gear cluster
