sunl 4x4 400 sla
Old Dec 3, 2011 | 10:25 PM
dooden's Avatar
Talking sunl 4x4 400 sla
Push button 4x4 stopped working first would blow fuse now not doing anything, any suggestions? Thanks.....
Old Dec 4, 2011 | 09:10 AM
Jaster94's Avatar
follow the wiring harness down to the solenoid and check the wiring's intergrity. something is grounding out on you. also, check for continuity from your switch down to the solenoid and then through it to the shifter.
Old Dec 4, 2011 | 10:26 AM
dooden's Avatar
Cool 400 sla 4x4
Thanks Jaster94 getting on it itoday!!!!!!
Old Dec 4, 2011 | 04:45 PM
Jaster94's Avatar
i'm unsure exactly about your machine. i think it has a shifter solenoid or something else that actuates the shifter for 4x4. BUT, either way, you'll be able to see whether or not your wiring is the culprit.
it may look like this......unsure though....sorry
Oem Electric Actuator for 4x4 Atvs - Od409-01 - Odes 400cc Engine Parts - By Engine Size - In Stock at Sunlpartsonline Com - Electric Actuator That
Old Dec 7, 2011 | 09:26 PM
dooden's Avatar
Thumbs up
The weathers been pretty crappy here, hopefully i can get to it this weekend, will keep you informed thanks for the info.....
Old Dec 9, 2011 | 07:52 AM
Jaster94's Avatar
Ugh! the weather can't be too crappy. if it's cold, bundle up and ride the snow! that's what we do when it snows here. ALL TERRAIN VEHICLE. that's the ticket. but we understand. we have some crappy weather also that makes riding horrible. let us know.
Old Dec 10, 2011 | 06:07 PM
dooden's Avatar
After opening the harness and pulling apart i found that it was the harness, two wires were touching. Thanks for the help, and your right the weather isn't as crappy as what your taliking about, we never have snow. lol
Old Dec 11, 2011 | 07:00 AM
Jaster94's Avatar
glad you found the problem with your quad! enjoy it and put a lot of hours/miles on the machine and have fun
Bigredjeep
Apr 10, 2020 02:55 AM
Atvnewb88
Aug 19, 2015 02:22 AM
Atvnewb88
Aug 13, 2015 06:48 AM
WILLLANE8302
1) Engine problems..
Aug 7, 2015 08:24 AM
Mobyguzzer
Apr 28, 2006 11:25 PM
