Installing a fuel filter
Old Dec 20, 2011 | 08:44 PM
ezhoops's Avatar
Default Installing a fuel filter
I recently installed a fuel filter and I think i did it right.
I cut the fuel line between carb and fuel tank and installed with arrow pointing toward the carb.
I ran the quad after and no issues
Old Dec 20, 2011 | 09:31 PM
Scooter86's Avatar
Knows Old ATV Questions!
Sounds like you did it right o me, are you having an issue with it?
Old Dec 21, 2011 | 07:15 PM
irishdude's Avatar
if im thinking of the same filter you used its correct, the only reason for the arrow is that on the filter i used the filter paper inside it is in a sort of funnel shape, so you actually want it in the opposite position compared to using it as a funnel so that the flow of fuel doesnt tear a hole in the centre of it where the dirt would built up, instead it builds up around the bottom of it, closed to the casing where it is stronger. so basically im pretty sure you have it in correctly
cody500ho
14
Aug 14, 2015 05:03 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
