need hub and spline info/parts
Old Dec 28, 2011 | 11:58 PM
HEBTEXAS's Avatar
Default need hub and spline info/parts
ok here i go baja wilderness trail 250 hub is damaged and spline is worn on axle. where can i get both these parts
Old Jan 4, 2012 | 06:41 PM
HEBTEXAS's Avatar
anybody???
Old Jan 15, 2012 | 01:58 PM
blain's Avatar
Default hub
i have the same one with the same problem hard to find but i got mine going 3 days ago i put a 2002 bear tracker on mine they are a perfect fit i got them off ebay .99 to 2004 bear tracker is what your looking for.
Old Jan 15, 2012 | 10:17 PM
HEBTEXAS's Avatar
ok so 2004 bear tracker parts will fit? does it mater what size like 250, 300,400?
Old Jan 16, 2012 | 05:37 AM
blain's Avatar
Default hub
i don;t think it dose you can go where i went to check them out. go to BOATS.NET you will see all the bear tracker parts diagrams on the atvs all kinds .
Old Jan 16, 2012 | 05:54 AM
blain's Avatar
Default parts
I just looked it up the part number for it is the same but first 3 numbers are different from a 250 to a 400 so you might have to get a 400 one i;m guessing hope this helps you out the chinise ones are very hard to find i found.when i was looking for mine but the bear tracker one i put on fits perfect.just find out your axle size and you;ll no.
Njrider1230
Jul 29, 2023 05:16 AM
blueandy88
Sep 7, 2020 03:11 PM
bmark0610
Sep 7, 2015 09:42 PM
blueandy88
Aug 31, 2015 12:42 PM
blueandy88
Aug 30, 2015 08:26 PM
